Group: DynoMotion Message: 7230 From: az9633@ymail.com Date: 4/10/2013
Subject: Feedrate value changed.
I'm not sure how this happened but it looks like the KCNC feedrate value has changed. It used to be 0.8 was 0.8 inches per second.
Now if I enter F0.9 it runs veerrrrrrry slowly. In order to get the speed that was originally f 0.8 (ips) I now have to enter about F 30.
If I remember correctly this speed designation changed when I was attempting to use Feedrate override alider on the main screen.
Reloading the init file or cycling power didn't change anything.
Any Suggestions?
I'm using version 4.30
AZ
Group: DynoMotion Message: 7233 From: Tom Kerekes Date: 4/11/2013
Subject: Re: Feedrate value changed.
Hi AZ,
Could you be in mm mode instead of inches?
Maybe you changed a parameter?  What is your max Velocity set at?
Group: DynoMotion Message: 7292 From: az9633@ymail.com Date: 4/19/2013
My velocity is set to 1 on the Kcnc trajectory planner screen where I enter counts per inch as 1. Inverse distance is 250 on the snap amp setup.
AZ
> Hi AZ,
> From: "az9633@..." <az@...>
> Sent: Wednesday, April 10, 2013 10:09 PM
> Subject: [DynoMotion] Feedrate value changed.
> Any Suggestions?
> AZ
Group: DynoMotion Message: 7297 From: Tom Kerekes Date: 4/19/2013
Hi AZ,
The Tool Setup Parameters are all always specified in units of inches.  But the Interpreter (GCode) can be in inches or mm.  Check that.
